Tom/Barb wrote:
This week, we had a power outage here on the island due to high winds and heavy rain. We were out of power for about 5 hours. during this time we retired to the coach. While there we discovered that the inverter charger would not connect to the battery pack. We then used the Gen-Set. to power up, which it did as advertised.
The next day I discovered the main line fuse between the battery pack and the inverter was smoked, It had over heated and melted the entire fuse and holder. totally destroying it.
Our new Magnum inverter / charger control panel would show a low battery and shut down when the gen-set was shut down. while on 50 amp service (after power was restored) it looked normal. but would show the battery at 13.8 volts.
today I called Newmar to see if the fuse and holder was available, yes it is at 130 bucks.
the old fuse was not blown, just burned, the theory is, it had a loose connection which created a high resistance connection and heated burning the whole thing to ash.
heres a 200 amp system for $13 or a more original ehd one for 64$
https://www.amazon.com/KnuKonceptz-Bassik-Gauge-Line-Holder/dp/B06WRVM461/ref=sr_1_6?ie=UTF8&qid=1511015833&sr=8-6&keywords=200+amp+fuse+and+holderhttps://www.amazon.com/Go-Power-FBL-200-Class-Block/dp/B001539B60/ref=sr_1_8?ie=UTF8&qid=1511015833&sr=8-8&keywords=200+amp+fuse+and+holder
