topbuddy10 wrote:
My coach is up for the winter and I have it plugged into electrical.
Both of my batteries(I assume you mean your house batteries) appear to be charged however, when I unplug the system (what system?) there is no coach power (12vdc or 120vac?). I have checked the fuses on either side of the relay in the front of the unit (what unit?) and they are ok, Any ideas of what the cause may be or how to fix it? The coach is a 91 Winnebago Chieftain.
Being a coach that old, not sure that you have an inverter...more than likely just a converter. In which case, once you unplug from shore power, you won't have any 120vac.
But your word usage is unclear about what specifically you are talking about.
