LaTriker's avatar
LaTriker
Battery Problems
I drove my MH today after it had been parked for three weeks plugged into 20 amp power. I drove 15 minutes then stopped for lunch. I checked the voltage before leaving the MH. The voltage display showed 12.5 volts. The only things on at the time were the residential fridge, the inverter and the battery charger. I came back to the MH in one hour and voltage showed 10.7 volts. The inverter had cut off. I cranked the generator and the charger started bulk charging. After about one minute, it switched to absorb charging. Does that sound like an inverter problem or are the batteries shot? I have four six volt batteries that are three years old.
