Jerry_AmersonExplorerJun 12, 2017Battery switch causing heat upI put a 60 amp battery switch in line on my ground side where my two 6 volt batteries connect, hot from one side and ground from the other with switch in the middle. When I was at the races my genera...Show More
pauldubExplorerJun 12, 2017I think your switch and the wiring are undersized. What gauge wire are these other main lines that you mention?
Related ContentSwitching toiletsAutimatic Transfer Switch?AG battery switchoverBattery switchAutomatic Transfer Switch (ATS)
