Jerry_AmersonExplorerJun 12, 2017Battery switch causing heat upI put a 60 amp battery switch in line on my ground side where my two 6 volt batteries connect, hot from one side and ground from the other with switch in the middle. When I was at the races my genera...Show More
photobugExplorerJun 12, 2017Anyone know of a good wire diagram to hook up disconnect? I've got dual 6v in series. should the switch cut off the positive or negative?
Related ContentSwitching toiletsAutimatic Transfer Switch?AG battery switchoverBattery switchAutomatic Transfer Switch (ATS)
