Sam_Spade
Jun 13, 2017Explorer
photobug wrote:
Anyone know of a good wire diagram to hook up disconnect? I've got dual 6v in series. should the switch cut off the positive or negative?
You don't need a "diagram".
Which ever cable you pick, you effectively cut that cable and insert the switch at that point.
Electrically, it makes absolutely NO difference which cable you insert the switch into. You could even put it in the cable that is between the two series batteries.
It most often is put into the negative cable because that is the safest place to be doing the work.....while all the other cables remain connected.
38,782 PostsLatest Activity: Sep 10, 2026
