time2roll
Jun 13, 2017Nomad
photobug wrote:By convention all fuses and switches in the RV are on the positive side. I would continue with this to be consistent. Electrically it will accomplish the same effect on either side.
Anyone know of a good wire diagram to hook up disconnect? I've got dual 6v in series. should the switch cut off the positive or negative?
Wire diagram?
Remove all wires from the the positive RV battery terminal and connect to the switch. Get a new jumper from the battery terminal to the switch.
Minimum wire size should match the largest wire connection.
http://www.genuinedealz.com/custom-cables
38,782 PostsLatest Activity: Sep 10, 2026
