enblethen
Jun 13, 2017Nomad
Now I see that you installed the switch in the jumper between the two batteries. Not a good idea, but it will work.
Are you sure the AIr Conditioner is routed through an INVERTER? I doubt it!
Do not confuse an Inverter with a Converter.
An inverter changes 12 volts DC to 120 volt AC
A converter changes 120 volts AC to 12 volts DC.
What size wires leave the batteries? If it is #6 then #6 would be good as a jumper. If larger then that, you need to at least equal that size or larger for jumper.
60 ampere switch is pretty light. I would have been looking for a 100 or maybe 200 ampere switch.
Make and model of converter?
Make and model of inverter if equipped?
38,782 PostsLatest Activity: Sep 10, 2026
