Hank_MI
Oct 28, 2017Explorer
I'm a little confused about when they work and when they don't. It started and drove then you hit the 'main' switch? Shouldn't start with main disconnected/off. Then you connected AUX batteries and they didn't work. Was main still connected, was engine still running? Maybe you could explain it again.
Engine alt should charge all batteries. If lights only work when engine is running it sounds like aux batteries may be dead. Have you plugged into shore power to see if lights work? Check voltage of AUX batteries.
