Hank_MI
Oct 28, 2017Explorer
wildmanbaker wrote:
Hank, with Fleetwood products, if the batteries are disconnected, sometimes trying to re-close the disconnect switches does not work. Turning the key to Start seems to close the disconnect switches. I do not know why, but this has worked on numerous MHs. Yes, the OP is not clear as to what the problem is. Seems to be saying it works, but does not work?
Well we had a 94 Bounder. Motor/ignition only worked with Main on. I had the Main disconnect solenoid fail and had to replace that. With no shore power and AUX off no lights or 12v to anything not running off ignition. Not sure off the purpose of the Main disconnect on his HM if the engine starts when it's off. Almost sounds like someone has made a few mods, maybe to work around a bad disconnect solenoid.
