RLS7201
Oct 29, 2017Explorer II
cm2785 wrote:
Thanks guys I’ll check it out tomorrow but I checked my dads 08 Bounder and if I turn his main switch off and try to start it, It too starts up. Also, my disconnect must work as when the main is off my camera and lights are off. I have a sneaking suspicion my 6v batteries could be shot and everything is running off the Main because of that.
You can not always go by what other year Bounders do electrically. The RV Customs Products BCC has been in a state of evolution since its inception. As an example, in mid 1995 the BCC was redesigned so the chassis battery will charge when plugged in to shore power (CB 200 Rev. C). Also some where in its evolution, the ignition circuit was removed from the main relay due to the engine dying, while under way, if the relay failed. Safety issue. Then a feature was added to close the relays if the ignition key was turned on or you plugged into shore power.
So now all you need is a responder to tell you how his/her Provost works. GRIN
Richard
