YC_1
Oct 06, 2017Nomad
Gordysvette wrote:
Thanks YC 1 , should I leave the RV plugged in with both switches off ? or does it matter ?
Thank you
Checking the voltage on the batteries before and after you plug in and then turning the switches on and off to verify they do not effect the charging system you can leave them off or on when plugged in. But if one effects the charging path you definitely want to leave that on when plugged in.
