AstroRig57
Oct 07, 2017Explorer
A 2013? You would think they would have a decent multi-stage inverter or converter/charger but then you never know.
As others have noted, if you have good multi-stage charger, like one from Progressive Dynamics, Iota, Magnum or Xantrex, that has a float or maintenance mode there should be no problem in leaving the battery disconnect in the "On" position.
On the other hand, if you have one of the "battery boilers" as I call them, you'd want to cycle the switch off and only turn it on when needed to keep the batteries charged. On my old rig, and before installing a Progressive Dynamics unit in my newer one, I used to turn the disconnect to off and use a Deltran Battery Tender Plus to maintain the batteries.
