mleekamp's avatar
mleekamp
Battery Tender on E450 Chassis? Shore Power does all?
We are not new to RV'ing (had various TT's for 20+ years), but are new to our new Class C w/ the Ford E450 chassis.
We have it plugged in to shore power (I have a 30a RV plug on the side of the garage just for our former TT's and now the motorhome) for winter.
*Will this suffice to maintain both house and chassis batteries?
*Will shore power only help house batteries and I need a battery tender for the chassis battery?
Appreciate guidance.
  • I know for sure mine will charge the chassis battery when the coach is plugged in. It's easy to check, plug in to your outlet, then check the under hood battery for voltage. If it's over 13v, you're charging. Let it sit for some time before checking though, it can take a while for the relay to connect them up (in my experience anyway).
    It's not a function of the Ford portion though, it's a fuction of how the motorhome manufacturer wired up the chassis/house batteries.
  • Acquire a trik-l-start. Then the chassis battery will be maintained whenever the RV is plugged in.
    Even better--get a modest solar charging system.
  • You can put a volt meter on the chassis battery and the coach batteries while at rest , should read about 12.6 volts.
    Then plug in the MH to shore power and do the same voltage test , should then read about 13.4v or higher.
    On some MH's, the MH converter will charge all the batteries, it will depend on how its wired. An isolator solenoid (which acts as a one-way electric gate) should protect your chassis battery from draining while boondocking etc. but that gate would open up to allow your converter to charge all the batteries.
    If not, then you need to take measures to monitor the batteries not being charged.
    You may have a BIRD or a derivative of it my Tioga has one and I know of many RVs that have them,It will charge thru the Continuous Duty Solenoid Relay as mine does. It may be located in your battery bay as mine is.
    Click For Full-Size Image.
    It senses voltage on the coach and chassis batteries and charges the one that needs it most,when it is at full charge it will return to the normal function.
  • I have a similar rig. I don’t think the shore power will maintain the starter battery up front, although it should take care of the house battery(s). I’m not 100% sure of this.
    You might try an experiment: Put a meter on the starter battery... plug and unplug the shore power connection (or turn it on and off) and see if the meter changes.
    Just a thought.
    I use a very small dedicated solar panel connection to the starter battery via the cigarette lighter-style connector to maintain the starter battery.
    R
  • Mlee,
    I can not say specifically for Jayco, but few MH of any type maintain the main engine (chassis) battery with the house converter. It is even worse now than it was as many ECU draw more when not operating than they used to.
    First, I would get the specifications of house converter that was installed and if it is a 3 or 4 stage unit, leave it alone. And, if it is, then get or make a silly jumper to bypass the combiner/isolator so that can maintain both.
    If you don't like that ides, there are lots of little battery maintainers that can be installed easily.
    Matt
  • House battery will be fine. Chassis battery is no different than any other vehicle regarding charging level. This would be my own experience and do not offer mechanical or technical assistance!
