bigcitypopo's avatar
bigcitypopo
Battery upgrade.. how in a 4winds with....
an outside battery tray, that will hold one group27...
move the batteries inside and use AGM?
it a 4winds Majestic 23... it is my mom's she got it from reserve america.. its been a great coach. the single skyline battery in it is on its way out. it only holds 12.0v after a full charge.
any recs would be great, or any upgrade ideas?
i'm just now learning the quirks of her class C,
  • If you mount a battery on the frame under the coach, it would make it very difficult to check water levels on a flooded cell battery. This would be a good reason to consider AGM batteries. You can not mix flooded cell and AGM batteries, so this would mean that you would need to buy two AGM batteries.
  • Pianotuna.... I was thinking the sme... But her coach already has limited storage....
    Path1... That thing is neat... I'm gonna crawl under that rig and look again
  • Majestic 23
    I have 23P model. I can only get 1 group 27 the way mine is also. I have not done this yet but have planned for upgrade (as far as projects go). I'm going mount the other battery with this. Have heard of no complaints. https://www.etrailer.com/RV-and-Camping/Tork-Lift/TLA7727.html
    One reason for holding off is price, which is crazy. It's not the $152.00 it's what I get for the money. I've had my eye out for metal box size of battery and then make a hook to fit on frame.
  • Hi,
    I chose to have one of the out door storage compartments modified to carry the weight of four batteries. Much cheaper than buying AGM chemistry.
