rayleepotter's avatar
rayleepotter
Bed slide
I have a 2015 Winnebago Journey 36M - I have a king sized bed which moves side-to-side. The bed slide only works periodically - How do I access the bed slide mechanism? Can I perform some maintenance on the mechanism so it works more fluidly and frequently?
Thanks for your help.
  • wa8yxm wrote:
    Describe the slide. as follows
    With the slide extended are there cables visible? (yes no)
    A kind of "Wavy" metal track on the side (yes/no)
    Under the slide Toothed rails (yes/No)
    Or Hydraulic cylinders (yes/NO)
    Pick one of the above or if I've not described it please do.
    What is the reason for asking.. Different slides different instructions.
    At lest two of the slide out systems I've described use a current sensing controller (same as Kwikee steps do) the theory is when the slide out reaches end of travel the motor stalls and draws more current the controller senses this and shuts off.. Well other things can cause current to increse and trip the OFF switch.
    Unless I am miss Reading he is talking about the bed and I could be miss reading your post also.:)
  • wa8yxm's avatar
    wa8yxm
    Explorer III
  • rayleepotter wrote:
    I will look under the panel under the bed storage area. Yes some days it works great other I can not get it to slide at all.
    If it's intermittently working like that - sometimes perfect, sometimes not at all - I would suspect an electrical problem, like a loose wire. Can you hear the motor engage when it doesn't work?
    Is this slide electric or hydraulic?
  • I will look under the panel under the bed storage area. Yes some days it works great other I can not get it to slide at all.
  • I think more info is needed. When you say "works periodically", what does that mean? Some days you push the button and nothing happens and other days it works fine?
  • Look in the storage area under the bed. Is there an access panel laying on the floor? My 2010 Winne has a screw slide with most components accessible right there.
