Diplomat_St_Poo
Sep 27, 2018Explorer
enblethen wrote:
Does your shear pins look like these Roll pin
RBW indicates that you have a Brake motor. This could be coming on for some reason while the slide is still moving in.
I have tried two types of shear pins. The roll type and the solid type. Both have failed.
I had to remove the motor to replace the pin so we bench tested the brake. It comes on and off as specified. When you press the override button on the control panel you can hear the click of the brake release.
Great ideas though. Thanks for responding.
As you can see we have investigated many things and are still stumped. Being careful not to hit the limit when we are putting it in and out works but there must be something we are missing. I can use it this way but would like it to work correctly. Frustrating to say the least.
