Diplomat_St_Poo
Sep 27, 2018Explorer
fairway2002 wrote:
If I was trouble shooting. I would start with the plug marked signal. Maybe a open and closed sw. with using the body as a ground. Should be an easy test.
Good Luck
Our next step was to check the control module wiring. But before doing so I contacted the manufacturer American Technology and they are saying that there is nothing built into their controller that limits or stops the slide. They thought it might be a switch in the motor but as far as we can see the only thing on the motor is the brake. Odd though because other controllers similar to mine say dual slideout current controller. They look very similar to mine.
