Diplomat_St_Poo
Oct 08, 2018Explorer
subtroll wrote:
We experienced bedroom slide roll pin failure many times until I discovered that the slide was not perfectly level. It was visible outside by looking at the squeeze of the rubber seal. I raised the rear corner about 1/4 inch and added a 2 x 4 stiffener in the outside wall, Problem solved.
The slide appears level. All corners seem to come in equally and seal. But we will certainly look at that a bit closer.
Thanks.
