AikenRacer wrote:
Our bedroom slide sticks when extending. You hit the extend button and the slide moves about an inch then stops. It will go back in ok. If you give it just a little push when extending, it goes out fine. Once out, it comes in ok. Have checked for obstructions and saw none. The bottom outside of the slide is solid and has two small tracks on it. I think all four slides are hydraulic. Any ideas on what may be causing it to stick...Thanks!
Only that it might not be level, which could make the difference...
Are ya sure they're hydraulic?
