mmccray100's avatar
mmccray100
Bedroom Slide won't Extend
Regarding my 1999 Winnebago Chieftain using HWH Series 200 hydraulic leveling jacks with 2 slides.
I was parked for a week before making a propane run. The slides and Jacks retracted normally. When I returned, the levelers worked per normal and living room slide extended. The bedroom slide went out about 12 inches and stopped. I retracted then tried to extend again but no action at all. I don't hear the pump, only the switch clicking.
I'd had a problem retracting both slides back in March. That turned out to be caused by low fluid. I checked the level this time. It took 1 1/2 quarts, but I'm still unable to extend the bedroom.
I've got the switch exposed and will check it. But first I decided to call HWH. They said they are very busy and it would be a week before someone would call me back!
So now I'm reaching out to rv.net folks. l'v received great help before.
TIA
Mike
