bsport
Jun 04, 2014Explorer
Bedroom slide
Hi Again:
Well something new that I need help on, this forum has been a great help in the past. My bedroom slide starts to extend then the bottom moves out and the top stops, if I push on the top it will move. The slide is tipped at angle when this happens. The slide will not open all the way it stops about 3" short. It appears that the slide is not moving at same time (top & bottom). Slide seems to tip when going in or out, when I closed it today it did not close. The top went in all the way but the bottom did not, I had to push it closed from the outside. Is there some type of adjustment, I see now that the inner rubber seal on top left is tore. Also last rain storm with the slide open the carpet on the lower right side got wet first time ever.
(2003 Four Winds Mandalay)
Again Thanks in advance
