jgellis586's avatar
jgellis586
Bedroom tv mount
Been lurking for 4 years and just purchased a 2017 Thor four winds 28z. Question I am planning on mounting a tv in bedroom but the wall seems flimsy. What would be the best way to mount? Looks like screws or bolts will protrude through bathroom cabinet. I am planning to use washers or a block of wood to add additional support. Will this work and what have you done to mount the tv.
Thanks in advance for your help.
    I see that RV has an optional wall mounted TV in the bedroom. Any chance of seeing another one on a lot and checking to see where its mounted and the type of mount that's used ? Chances are your MH might have the needed reinforcement in your wall. You can feel around for any bracing behind the wall, take off the wall covering or call Thor for advice. Do you have a TV cable connection somewhere on the bathroom wall ?
