tom___betty's avatar
tom___betty
Beep Beep Beep
We have a new Winnebago Aspect and have a slight problem. When the emergency brake is unengaged & unit is ready for traveling we have a continual beep beep sound coming from drivers side dash. When the emergency brake is engaged the sounds goes off. It is not the sound that you get when the brake is engaged. Not as loud. We have a trip planned but dealer cannot get us in for another 3 weeks. If anyone has any suggestions as what this might be maybe we could fix it ourselves.
  • could be a bad ground for the e brake system. if the sound is faith.
  • Check and see if the red lights are off on Leveling system.
    Should have a Green light and a yellow one that shows low side.
    Sounds like jacks are not all the way retracted.
  • Steps are inside door & I have read the complete manual & can't find anything on this. Just thought someone else might have had the same problem.
  • ARE YOUR STEPS RETRACTED ALL THE WAY? DOES THE MANUAL LIST ANY ALARMS.
  • We checked & rechecked the leveling system. All seemed ok. We did take unit to our local ford dealer & they said it was a coach problem. This unit is a 2014 with auto leveling system.
