donfrump
Dec 26, 2015Explorer
Trackrig wrote:donfrump wrote:fishingbob61 wrote:
In the picture of the pump is a sensor with 2 red wires, unplug the wires and if the beeping goes away it is either low on fluid or a bad float, the red wires are to the float. The float is cheep and easy to replace.
if it was a low fluid why would it only beep when put in gear?
When you're not moving, the MH has no problems with the jacks being down or at least registering as being down because you could be parked in an RV park. However, the MH does have a problem with you moving with them down or at least thinking they're down.
When the levelers are retracted, they force the fluid back into the pump holding tank where the sensor reads the fluid level. If the level isn't high enough, the sensor believes at least one of the levelers is still down.
Assuming the levelers are up all of the way, either the fluid is low or the sensor is bad. Again, when this happened to me, my fluid level looked fine to me, but a put a touch in and the beeping went away. It's been happy for two years now.
Bill
maybe your system works this way HWH do not. when my jacks are down and I turn the key on it beeps and the lite on dash lites up until jacks are totally retracted
there is a up position senor at each jack if there out of sync or jacks down even a c-hair it will beep
