In Texas, you MUST volunteer that you have a CHL when first talking to an officer. EVEN if you are not carrying. Failure to do so, can result in a Ticket and/or arrest. You also state WHERE your weapon is when you inform him. FAILURE to comply with anything the Officer asks/tells you do may result in being arrested. The fact that the officer may be wrong does NOT exclude YOU from being subject to arrest. You can still be convicted of interfering with an Officer even if the original charge was unfounded. NEVER argue! Your time to argue is later in court. Being arrested, because YOU think you are right, just causes YOU problems, not the officer. Doug
