- Triker33ExplorerFor those who don't know what it is, CPL stands for Controlled Parts List. It is a parts list that is specific to that series engine and configuration. Remember that the 5.9 comes in several different varieties. The CPL is hte number a mechanic or parts guy will use to get the right part for that engine configuration. Things like heads, injectors, valves are configuration specific. To find the CPL nuber look on your engine at the front drivers side of the timing case. There is a data plate with lots of info. CPL is listed in there.
- William_WillardExplorerWith the rear radiator,you`re in for a long hard day when you go to replace them -- Bill Willard
- Mandalay_ParrExplorerThose items may have been supplied by the chassis mfgr not Cummins
- mike2wheelsExplorerA couple of the local service shops use Napa. I've also used rvchassisparts.com for Cummins.
- Bruce_BrownModeratorYour local NAPA would be able to help you out.
38,769 PostsLatest Activity: Mar 28, 2026
