- crcrExplorer
lanerd wrote:
Water can sit in a fresh water tank for several months without experiencing problems. However, if the tank was not sanitized prior to using it this season, then the water in it should be drained and the tank sanitized as indicated above. You don't have to use a chlorine mixture as hydrogen peroxide will do the trick without the chlorine odor.
Ron
How much hydrogen peroxide per 10 gallons of water? - lanerdExplorer IIWater can sit in a fresh water tank for several months without experiencing problems. However, if the tank was not sanitized prior to using it this season, then the water in it should be drained and the tank sanitized as indicated above. You don't have to use a chlorine mixture as hydrogen peroxide will do the trick without the chlorine odor.
Ron - ChooChooMan74ExplorerAre you asking to sanitize the system? The bleach method is good for that. Purifying the water for a shower? For drinking, I just run my tank water through a PUR filter.
- 2oldmanExplorer II
newman fulltimer wrote:
His home water doesn't likely sit in a small tank.
why purify it?Do you purify your shower water at home:h - HondavalkExplorer II1/4 cup of bleach per 15 gallons of water. Let sit 3+ hours, drain, refill with water, drain again
- Matt_ColieExplorer III'm sure you mean the potable tank and not the holding (black) tank.
The best and simplest way is to dump the tank as refill it with city water that has a chlorine residual. If you live on your own well, just talk to a friend that has city water.
Dumping in bleach is a real bother because you will probably get too much and then the water will "swimming pool" for a few fills.
Matt - donn0128Explorer IIWhere did you fill it from?
- newman_fulltimeExplorer IIwhy purify it?Do you purify your shower water at home:h
38,738 PostsLatest Activity: Jul 26, 2025
