carringb
May 13, 2014Explorer
tpi wrote:
Those downshifts keep the torque converter cooler.
X2 - The E4OD torque converter strategy does not keep the clutch locked in high gear under heavy load. I'm guessing the stock clutch just isn't strong enough to allow that. Once it unlocks, your trans temps will skyrocket. Lower gears reduce the heat generated by the T/C.
38,769 PostsLatest Activity: Mar 31, 2026
