Sea_Dog
May 21, 2014Explorer
x0054 wrote:
You guys might be right, torque converter may not be capable of taking the more load, but I am telling you, the way the engine feels, I think it could easily, without even trying, pull the RV up almost any hill in the 4th gear. Is there a way to perhaps connect a light to the transmission somehow so it would light up when the torque converter is locked. Just out of curiosity. I want to see when it locks up, and when it disconnects. Perhaps I can modify my driving style to get it to disconnect less often.
I usually drive with cruise control set to 55mph, so I doubt the speed is a problem. I guess there isn't much of a problem, since from what it sounds like, my milage is right in the ball park. I was just hoping that I could get a little more :)
Do not use cruise!
That is what is causing your abrupt downshifting.
If you are concerned about a couple of miles per gallon,
Rving is not the hobby for you.
(/93 Ford 460, 22 ft class C, 260,000 kilometers running strong)!
38,769 PostsLatest Activity: Apr 04, 2026
