blownstang01
Sep 07, 2018Explorer
Just from my personal experience with the Platinum system I installed on my 31' class C. I have not used their automatic system. With that said, I am extremely happy with the Platinum system at half the price. It's pre-programmed when you push 'start' it brings both front jacks down and lifts the front a fair amount, then it brings the rear jacks down and stops a few inches less than the front. On my particular RV this program actually levels my RV perfect in my driveway and I assume any close to flat surface. You can then manually adjust it from there if required. We have only been to two campgrounds since installing them (maybe 10-12 trips) that we needed additional adjustments. One State park was so off level that I couldn't do it with the jacks alone and had to do some blocking, but the auto system would not have changed that. Again, I have no experience with the auto system but personally would not spend the extra $$.
Plus, with the brackets already installed it's a breeze.
Pics of mine installed here >> https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29661573.cfm
Good Luck
Good Luck
38,769 PostsLatest Activity: Apr 03, 2026
