How did you bleed the levelers Also make sure your battery is fully charged. . Directions say to have the motor home off the ground enough that jacks will extend without touching the ground. Let them sit like that for about 30 minutes. Check fluid level with jacks retracted. Level should be 3/4 to 1 inch below top. As mentioned before, take the fill caps off and retract the levelers. See how much fluid comes out. When I bleed mine before I let it down I ran my levelers up and down 10 times. After that I had no more problems. I hope this helps.
