koda55 wrote:
How did you bleed the levelers Also make sure your battery is fully charged. . Directions say to have the motor home off the ground enough that jacks will extend without touching the ground. Let them sit like that for about 30 minutes. Check fluid level with jacks retracted. Level should be 3/4 to 1 inch below top. As mentioned before, take the fill caps off and retract the levelers. See how much fluid comes out. When I bleed mine before I let it down I ran my levelers up and down 10 times. After that I had no more problems. I hope this helps.
When you ran them up and down 10 times did you do it with the fill caps off? Or did you just retract them that way and then put the caps back on first?
According to Bigfoot only the 2000 and up jacks have replaceable seals in them.
Bleeding the system might be a good idea too.
