koda55 wrote:
First, I made sure that my fluid level was 3/4 to 1 inch below the cap. After letting it sit 30 minutes I ran the levelers up and down with the caps on. I was told that the jacks must be fully extended and not touching the ground to bleed them properly.
It sounds like you still have air in the system plus to much fluid in the tanks.
Before I fixed mine they would go down but not raise the rv.
I have the Quadra BigFoot on my coach. The coach weigh's around 30K and the levelers will lift the coach up off the ground on any of the four corners with ease.
