Daveinet
Dec 03, 2014Explorer
Any kind of steering damper just masks the problems. A damper type device should be the very last choice in resolving handling issues. Start with proper air pressure, front end alignment, and good shocks. Next on the list and the most probable solution for nearly all gas coaches is a trac bar, front and rear, assuming you have a solid axle in the front. Normally trac bars solve most handling issues, because it actually corrects a design weakness of solid axles. Basically, your axle can move side to side, relative to the frame. This results in a delayed response to steering input. The delay means one is prone to over correct, and induce sway and loss of control.
38,778 PostsLatest Activity: Jun 10, 2026
