rgatijnet1
Oct 29, 2013Explorer III
timmac wrote:
Here is Bilstein RV shocks spec below :
•Hardened steel chrome rod
•Seamless cylinders
•Self-lubricating seals
•Machined valve components
•High pressure Nitrogen gas filled (360 psi)
•Monotube design
•Specific valving
Here is Monroe RV shocks spec below :
•Primarily for Class A motorhomes, both front and rear engine
•1 -3/4" bore
•2.38" reserve tube
•Single lip piston rod seal
•Low pressure nitrogen gas charge (60psi)
WOW > 360 psi vs 60 psi, I wonder which shock would ride smoother..
And then you have Koni FSD shocks which are NOT gas charged and, as some here have found out, ride the smoothest of all. .
38,780 PostsLatest Activity: Aug 05, 2026
