aauummm
Nov 03, 2013Explorer
John&Joey wrote:timmac wrote:
...I like my Bounder with the F-53 chassis but it just rode to hard on bumpy roads, no give, it just hammered hard, now its riding more like a car..
I keep reading the prior posts and I do understand that there is a theme here that airbags help, but it makes no sense why. The front end of the older 460 F53 is oversprung, that is the reason the ride is "hammered hard."
I would love if someone would explain to me how airbags that are suppose to increase the load capacity can soften a ride on a leaf spring suspension. If there is no give, then there is no give. Only thing I can come up with is the shackle on the leaf has limited give and the airbags are pushing the shackle to the upper limit when the airbag is charged giving more give to the leaf. If that really is the case the issue is the shackle and the airbags is just helping to cover up the true problem of a bad shackle.
Now as far as control in side winds I can see that very easily why airbags would work, just not in the ride. I can also understand them in the back where there is a load. There just simple is not enough parts in and old F53 front end to work with to make a silky smooth ride with the simple addition of airbags. If real world is saying different, then I would love to understand what is going on. Otherwise it might simple be a placebo effect after spending time and energy for the upgrade.
I just had the Kelderman Air Suspension (front and back) put on my 2011 22,500 lb (220" wb, 34.5'coach) Ford chassis last May. What Kelderman does is replace the OEM front leaf springs with multi-leaf variable rate leaf springs and then adds the Monroe shocks. This combo with the air bags makes for a softer, smoother front end and ride. The softer springs and shocks allows the air bags to work more. As part of the system, they install a heavier duty trac bar. I had them add on the Safe-T-Steer also. On the rear I had them install the Roadmaster heavy duty chrome alloy sway bar, leaving the OEM sway bar in place.
Overall, the sway is reduced noticeably and the ride is improved especially when hitting sharp bumps like at bridges or joints in the road. I am still fiddling with the air pressures in the bags, currently going with 60 psi in front and 70 psi in the rear.
I don't have any problem in side winds or with semis, but the coach handled pretty well in that regard before the suspension upgrade. Since I am still experimenting with air pressures I would be interested in knowing what other guys are running in their Kelderman air bags.
38,780 PostsLatest Activity: Aug 05, 2026
