thestarfinder's avatar
Dec 23, 2016
Black tank back up....
Monaco Windsor 2001.
After traveling for a few days and then a stay(1 week) in RV park black tank got full and when trying to dump thought slide gate was broken because nothing came out when opening it.
Well gate opened fine after checking but just a small amount of liquid came out not much solid..
Got coat hanger and opened gate poked around and got some stuff moving on me and ground but not a lot...
Tank indicator was reading down to a 1/4 tank..so I got some room in tank...
I'm thinking some what of a "poop pyramid" has formed near tank exit..
Someone advised to get some Rid-X and try that...And did that lastnight..
Does anyone know how long I should wait for the Rid-X to work till trying to dump/flush again?
Or any other "Black tank" back-up advice..
Thanks in advance,Tom
  • Depending on where you are You could find a place that will come back flush the tank and get it cleaned out for you. In the Phoenix, AZ area there are a couple of places that do this
    Are you using any chemical additives ?
    For future reference:
    If you don't like the idea of the chemicals in products made for that, just a little bit of detergent will help break things down.
    This often means that you are using the wrong kind of toilet paper.....or the occupants need a lie detector test to find out who is putting forbidden items down there.:E
    It can also mean that you didn't get it cleaned out good the trip before and now there is some near-rock-hard deposit at the bottom.
    I think Rid-X is very slow acting but others maybe can offer advice for the current situation. Hot water, detergent and aggitation would be good.....if it's time to move.
