fltrker's avatar
fltrker
Black tank fumes
Partially emptied the black tank as the receiving facility was full.
Buttoned up the line and closed all valves and drove 1/2 mile and black tank fumes started coming into the m/h maybe around the washing machine area. ?
When we Stopped the smell stopped. But as soon as we moved the next day. They came back.
What is the problem?
Where could it be coming from and how to fix it.
Stinky.
  • What do you mean the receiving facility was full? Huh? Once you start to dump you don't stop until your finished dumping. How did you stop dumping?
  • May not be the blank tank. I suspect you're smelling the gray tank which can be as bad as the black tank. Be sure all of the traps have water in them ....including the washer drain. If this does not help, then start replacing the air admittance valves under the sinks ($5.00 approx at Home Depot).
    I don't have a washer, so I've taped over the drain line so I don't have to worry about the trap losing water.
    Also be sure you don't have a stove burner slightly turned on as propane can smell bad also.
    Outgassing on a bad battery can be bad also.
    Good luck.
    Fred
