SJ-Chris
Feb 13, 2022Explorer II
Added a couple more clamps just for good measure.
While I was under there, I replaced the black blade valve which was jammed (...after getting to it, I saw it was just some toilet paper that was easily removed, but since I had the new blade valve I decided to just change it.
There's one thing I would do differently...the 3" rubber coupling that I used was 4 inches long. This actually pushed the whole valve/drain assembly over by about 2 inches. I have since found that they make these couplings in sizes less than 4 inches. So if I replace the other one I will probably use one of these instead since it isn't as long...
https://www.amazon.com/Valterra-F02-2103-Flexible-Coupler-3/dp/B00PHNCU30/ref=asc_df_B00PHNCU30/?tag=hyprod-20&linkCode=df0&hvadid=312089957955&hvpos=&hvnetw=g&hvrand=15711510602455972828&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9032145&hvtargid=pla-571372074181&psc=1
Did a small water leak test and so far so good.
Happy Camping!
-Chris
Happy Camping!
-Chris
38,782 PostsLatest Activity: Sep 10, 2026
