lucytravel12ExplorerJul 14, 2014Black Water Drain Leaks - Yuck!My '87 Falcon has a leak at the black water discharge. I've used a hard brush to clean around the valve, but it didn't help. It's parked in my gravel driveway, so isn't a problem at home, but I pres...Show More
lucytravel12ExplorerJul 14, 2014It's leaking right at the discharge - don't know what that valve is called. It's the round valve that opens when you drain it.
Related ContentHouse battery drainGrey water tank won't drain completelyBlack water won't drainBlack tank not draining!black tank wont drain
