lucytravel12ExplorerJul 14, 2014Black Water Drain Leaks - Yuck!My '87 Falcon has a leak at the black water discharge. I've used a hard brush to clean around the valve, but it didn't help. It's parked in my gravel driveway, so isn't a problem at home, but I pres...Show More
charlesExplorerAug 04, 2014Glad it worked out for you. I use mineral oil twice a year to oil the valves from the inside. So far so good.Nick
Related ContentHouse battery drainGrey water tank won't drain completelyBlack water won't drainBlack tank not draining!black tank wont drain
