onecolbs
Mar 12, 2015Explorer
bleeding air breaks
I have a 2001 bounder with 51000 miles. Should i have the break lines bled? And where do I find where the lines bleed from? thanks. Just trying to learn.
mowermech wrote:
Thank you. Now we know that in Ontario we can't adjust our own air brake slack adjusters. IF that rule applies to owner-operated, non-commercial vehicles, and IF that rule also applies to non-residents who may not have to have such a certification.
That may seem like a silly question, but here in the United States quite often the rules for commercial vehicles do not apply to the operators of Recreational Vehicles.
In fact, some states do not require an air brake endorsement on the driver license of the operator of an air brake equipped motorhome.
Dutchstar02 wrote:
"If they feel mushy, take a (/16 wrench and a balpeen hammer and get under there and adjust them."
I don't know what jurisdiction your air brake endorsement is certified in but in Ontario, Canada you cannot adjust your air brakes unless you are certified to do so. This means either being an air brake mechanic or MTO certified air brake adjuster. It not only is very dangerous to do so it's also illegal.
mowermech wrote:
Can you provide the statute from any jurisdiction that says it is illegal to adjust your own non-commercial air brake slack adjusters?
Passin Thru wrote:
/snip/If they feel mushy, take a (/16 wrench and a balpeen hammer and get under there and adjust them.
