wannavolunteerF's avatar
Jun 08, 2019
blocks for leveling under jacks and tires
I've been RVing a long while and primarily used "LEGOS" for under stabilizers in TT. Now have 38ft Class A weighing about 24K lbs and am unsure what to use under auto-leveling jack pads and under tires if they are leaving ground. Are the "LEGOS" strong enough? They are almost the same size as the jack pads (I do have large plastic landing pads for when on dirt or asphalt).
What are recommended for under jacks to keep them from having to extend so far? If wood, what size boards? I prefer lighter weight or something that doesn't collect moisture and bugs so easily. I am trying to make a decision between weight and convenience and cost. They will have to be stored in the bins of the MH or inside toad car, as I do not have a truck or open storage for wet, nasty boards..
  • Plywood blocks 1' sq, several pieces glued and screwed for 2" thick. Cut off one corner, install eyelet and rope loop.
  • I use square blocks cut from a 4x6, and more blocks from 2x6 stock and even some squares of 1 by material. My jacks don't need to deploy much. It's not the lightest, but not too bad either.
  • I used several layers of playwood nailed and glued together to form a block 1.5" thick. I have four of those. I also carry four other 3/4" boards to adjust as needed but I rarely need those.
