bobndot
Aug 02, 2023Explorer III
When your fuse blows you should be able to start turning on all your various 12v electrical items. Those that don’t work i.e. ‘outside tv’ or whatever else doesn’t work, you will then know what is on that circuit.
You probably have a short in one of those items , causing the fuse to blow right away.
Isolate each piece on the circuit. Disconnect them one at a time and then try a new fuse to see if it blows right away .
38,782 PostsLatest Activity: Sep 10, 2026
