klutchdust
Aug 02, 2023Explorer II
CA Traveler wrote:
Replace the fuse with a temporary light bulb. When you then isolate the problem the bulb will go out. Or use a buzzer for a audio indication. This saves a lot of hassle replacing fuses.
And don't overlook the obvious like the steps etc.
There was a switch on the floor/right side when you first stepped into my Cambria. That switch told the steps to extend /retract depending on what position the door was in. It took me a while to figure out that issue. Well, when I pulled away from the curb and the steps were scraping the curb was when I first learned I had an issue. The pin was bent and my guess was from vacuuming.
38,782 PostsLatest Activity: Sep 10, 2026
