timmac
Sep 12, 2018Explorer
39ft 11in motorhome is a lot of weight for the V-10, I noticed the specs says its on a 26,000lb chassis and I bet loaded it is max out in weight than add a 4000lb toad and that V-10 is lugging over 30,000lbs, Ford says the V-10 max working weight is 30,000lbs so that motorhome is working over time max weight every mile, no wonder it blew..
Newmar and other manufactures should not put that much of a RV on a gas motor..
