Driving home from Texas my Vortec 8100 decided to **** out on me 450 miles from home. I left it at a Chevy dealer to look at and rented a car to make it home. Chevy just called to tell me the engine i...
Just make sure that you find out what caused the problem. A bad MAF has been known to make the engine run lean and burn a piston. There could also be an issue with the ECM or O2 sensors. Basically you want to make sure that if you get a new long block that you do not use any bad components from your old engine when you bolt on all of the accessories.
