Golden_Doodle
Jan 28, 2018Explorer
Borg Dually Valve Kit
I recently took my 2018 ERA to a local tire dealer that is part of a national chain. I asked if they were familiar with installing Borg Duallyvalve kit and Bal Beads I was told they were.
I soon found out that they were not familiar with installing them even though they came with complete directions The rear inner wheels have to have the stems formed to be centered in outer wheels so that rubber support gromet would fit and tpms sensors would not touch wheels. They also refused to supplied Locktite and torque valve stems to proper inch pounds. Along with CBEX5 Balancing Beads comes filtered valve core and new stem caps. Upon leaving shop noticed that two of the tires did not have the proper caps. As it turned out they threw them in the garbage caps and filter valve stems along with one bag of Balancing beads. Bottom line is that i have no idea what else they did wrong and feel this is not safe.
Has anyone had these install in Northern California Sacramento- Roseville area that they could recommend.
