KUBSHACK's avatar
KUBSHACK
Brake and Hot lead from 7 pin plug
I have a 2015 Coachmen Leprechaun 280DS, have 7 pin plug on rear everything is hot except Brake wire and Hot lead, they have wires installed but can not find where they are dead ended. I have had numerous people tell me different areas but have not found them yet. Coachmen says there are no wires run and talk to someone else and they say yes under the seat but I have yet to find the dead ends. 2 different techs from Coachmen where their build say different things along with talking to 3 or more Dealerships that all give me their input from they are hooked up and there must be a problem to under the dash to who knows where. I really think everyone is just flock shooting and I'am asking for any ones idea where I may search next, thank you for your help.
  • Lets try this again the brake wire along with the hot lead are dead ended somewhere on the coach and no one can tell me where to find them to hook them up. They are run to the plug but no one can tell me where they are run to so I can make the final hook up.
  • OK, let's try this the simple way. First check to see if you have power at the brake controller. If you have power in and out then the controller is good. Just cut the output wire and splice in a new wire that you will run back to the 7 pin plug and hook it up. There is no sense to chasing a broken wire when it is much simpler to run a new one.
  • Can you explain a little better; You have 12V to all the pins at the connector except the brake and hot lead?
    Then you speak of "dead ends". I would expect there to be no power on those wires.
    Maybe proof read your post and fix grammar.. thx.
